Hey guys! I'm back to work on the Elsinore - first a few updates, then my next problem...
I just got this project off of the back burner! Been several months since I've tinkered with it. But best news... I finally got it running! Embarrassing yet simple enough, the timing was off. It was firing strong, but a bit
past TDC. I wouldn't have thought that alone would keep it from hitting or popping AT ALL. But sure enough, once adjusted so that the points began to open right when they should, it was ready. Second or third kick, I got a definite pop. I was so excited!
So this leads to my next mystery. The dadgum
kick starter. The very next kick, it popped again and just jammed my ankle so hard on the kick. And the kick starter stayed down. Didn't return to top. If you pull it up by hand, it will stay and you can kick it thru again, but it still stays down. Kind of feels like its in a bind a little. So I took the R crank case cover off. Coiled up starter spring? Pawl? Nah. They are both fine. Everything (to me) looked super clean and in tack. I just figured it was a fluke deal and put everything back and cover back on. And it seemed right. With spark plug out, it pushed through correctly and returned just like it should. Plug back in, under compression, still good. So I stand up and kick again, and BAM! Same thing. It popped, jammed my foot, and kick starter stayed down again. So I took cover back off, and still nothing stood out. I took that starter spring out, looked at it, put it all back together again, and again it seemed ready. This time I decided to pull it off with the golf cart in the yard. And for the first time since (I believe) 1975, this jewel was running. Sounds like a beast. But it was dark so after a first gear slow loop around yard I rolled it in. An hour later, I had to go back out there and just LOOK AT IT again.
And hey, might as well, give it a kick to see if she'll fire back up. But oh no... POP, JAM, ouch, kick starter does it again. No return and a little bind.
WHAT AM I MISSING?!? Looking at a schematic, I realize I didn't inspect the C shaped 'pawl spring' while I was in there. Could it be messed up and causing this? Is there something else I should check?
Thanks guys!!
Doug
