Tips for drilling mounting holes in new fenders?
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=434
Author:  J [ Thu Nov 25, 2004 12:20 am ]
Post subject:  Tips for drilling mounting holes in new fenders?
Anyone have a method for drilling mounting holes in new fenders so they are as straight as stock? Thanks!
J
Author:  Daniel F. Pullen [ Thu Nov 25, 2004 7:42 am ]
Post subject:  Holes
J: My advice measure scribe and drill on a bench press with a wood bit. You can use the wood pit as a pilot hole. I think the size is either a 7/8 or 1" bit. I have done quite a few sets this way.
Author:  Nathan [ Fri Nov 26, 2004 11:21 am ]
Another way to go is this. Take the new and old fender and mirror them at the flat mounting surface. Then take two pieces of plywood and sandwich the two fenders between them. Then take a scribe and go around the old mounting holes, scribing the new fender. Then just find the center of the scribed outlines and drill them out.
Author:  DEW [ Mon Nov 29, 2004 12:53 pm ]
Nathan has a good idea, but I'd use a transfer punch instead of a scribe.
The transfer punch gives you the center of the hole only.
