It is currently Wed Aug 13, 2025 4:29 pm
 Post subject: El electrical problem
PostPosted: Wed Oct 01, 2014 6:41 am
My CR125(CDI) has an electrical problem. I have a very weak spark at the plug(new) but I cannot find voltage anywhere else? Should I get a reading on something coming out of the mag? I have changed the stator, too? HELP!
PostPosted: Wed Oct 01, 2014 2:55 pm
I finally got the El to hit & start but it takes full throttle with choke on for it to barely run. Turn the choke off & it dies. I have cleaned the carb several times. Any ideas?
PostPosted: Sun Oct 12, 2014 6:16 pm
If you have weak spark, the CDI is bad. But it sounds like an air leak, from the manifold or bad crank seals.
alan
PostPosted: Sun Oct 12, 2014 7:17 pm
Here are readings I took off one of my CR125M ignition setups:
CR125M Ignition Readings (requires high-quality meter)
Stator Output @ 140VAC (narrow pulse - use peak-hold function)
Stator Pulse (trigger) @ 60VAC (narrow pulse - use peak-hold function)
Stator Output Coil Resistance @ 270 ohms (inductive)
Stator Pulse Coil Resistance @ 130 ohms (inductive)
Ignition Coil Input Resistance @ .7 ohms
Ignition Coil Output Resistance @ 10,600 ohms (inductive)
CDI Box Input Resistance @ 4.1 megohms
CDI Box Output Resistance @ 2.6 megohms
Do you have another working carb you can swap out?
