It is currently Wed Jun 18, 2025 10:17 pm
PostPosted: Mon Oct 20, 2014 7:45 pm
Will any other flywheels work with a stock mr175 ignition (mr250, mt125, mt250)? I need to replace one; it cracked where the woodruff key slides.
I realize the CR ignition is better, but I am trying to make this one stock.
PostPosted: Tue Oct 21, 2014 6:43 am
I'm pretty sure an MT125 flywheel will mount on the MR crank. It's possible you might need the MT stator too, which should bolt up fine to the MR cases.
I don't believe the MT ignition had a bad rep, it might work out well as an MR fix.
