mr175 flywheel cross match
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4385
Author:  mbilder [ Mon Oct 20, 2014 7:45 pm ]
Post subject:  mr175 flywheel cross match
Will any other flywheels work with a stock mr175 ignition (mr250, mt125, mt250)? I need to replace one; it cracked where the woodruff key slides.
I realize the CR ignition is better, but I am trying to make this one stock.
Author:  rayivers [ Tue Oct 21, 2014 6:43 am ]
Post subject:  Re: mr175 flywheel cross match
I'm pretty sure an MT125 flywheel will mount on the MR crank. It's possible you might need the MT stator too, which should bolt up fine to the MR cases.
I don't believe the MT ignition had a bad rep, it might work out well as an MR fix.
