Winker Relay https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4387 |
Author: | Doug B. [ Thu Oct 23, 2014 4:39 am ] |
Post subject: | Winker Relay |
Have the new blinkers and they will light up when activated but DON'T blink. Where is the winker relay located on a '76 MT250 Elsinore? Thanks! |
Author: | mbilder [ Thu Oct 23, 2014 8:42 am ] |
Post subject: | Re: Winker Relay |
The winker relay should be located under the gas tank. You should be able to see and access it without removing the tank. I have used a 12 volt relay, which works after a few second delay. I don't know where to find a 6 volt. |
Author: | OkieRob [ Thu Oct 23, 2014 6:11 pm ] |
You can use an automotive 6 volt relay ,it's just bigger on the outside. You would probably have to look at a early 50's vehicle to find one . On the mt125 it is under the battery cover. |
Author: | mbilder [ Thu Oct 23, 2014 11:28 pm ] |
If you haven't done so already, take a look at the shop manual in the manuals section of http://www.honda-elsinore.com/. On page 81 is an exploded view. Part no. 9 is the winker relay. |
