The kill switch shorts the coil input to ground, so your readings are most likely correct.
Try reconnecting the kill switch with the connectors exposed, set your meter to AC volts, and read across the connectors while kicking the motor over (switch on / spark plug shorted to ground of course). You should get a short pulse reading of some kind, probably less than 100VAC. If you get nothing, there's likely a problem under the flywheel (points/cam, stator coil, etc.) or in the wiring or coil.
_________________ '74 CR125M (175cc), '75 MR175, '82 RM250Z, '08 YZ250F, '14 Zero FX electric, '14 Zero MX electric, '18 Alta MXR electric
