only with the choke on
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4412
Author:  mbilder [ Mon Jan 12, 2015 9:16 pm ]
Post subject:  only with the choke on
I picked up a new smoker. Its a 250 and has been sitting for 15 years. The former owner said it was running when he stopped riding it. I pulled out the air cleaner and it looked like it had just been oiled and even had clean grease on the bottom. I checked the oil and it was full and clear. The tank had some rust particles. I tried to clean it out (there was some accumulation in and on the petcock).
I put some gas in and it started after 5 kicks. It only runs with the choke on and will die after a minute or so. It isn't a pulling a steady stream of fuel in as seen through the hose and fuel filter.
I pulled the carb and am about to go through and clean it. What should I be looking for that might cause it to only run when the choke is on?
Author:  rayivers [ Tue Jan 13, 2015 5:53 am ]
Post subject:  Re: only with the choke on
The pilot jet and/or pilot system passages may be plugged, and the float level may be low as well.
Author:  mbilder [ Sun Feb 01, 2015 11:44 pm ]
I think it was related to the air screw and Pilot. I took it apart and found goo on the air screw, so I cleaned it out again and it ran ok. It wasn't sucking fuel into the carb very well, so I took it apart again. I completely dismantled it including the choke. Blew it, pipe filtered and adjusted the float. Now it works great.
