PVL install '73 CR250
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4417
Author:  Ratmuss [ Tue Jan 20, 2015 4:28 pm ]
Post subject:  PVL install '73 CR250
Hey guys, I was hoping to get a few pics of where and how you mounted your CDI's on the Pvl conversion early model cr250's. New to this forum but it looks great! Thanks in advance.
Author:  t.read [ Wed Jan 21, 2015 10:19 pm ]
Post subject:  Re: PVL install '73 CR250
Anything in particular you need to see? I did one on a MR250 and I have a few pictures, but it went together pretty easily.
Author:  Ratmuss [ Thu Jan 22, 2015 9:44 am ]
I was hoping to see how and where the CDI is mounted. I have a couple of different ideas, but i dont want to re-invent the wheel if i dont have to.
Thanks!
Author:  rayivers [ Mon Jan 26, 2015 5:54 am ]
The CR250M and MR175 frames are pretty similar under the tank, so this might help with mounting ideas (CR125M ignition in MR175 frame):
http://i399.photobucket.com/albums/pp74 ... 1754-1.jpg
The coil mount is 1/2" x 3/4" aluminum channel mounted to the front OEM coil-bracket hole and the frame crossbar, using an MR175 skid-plate mounting clamp (P/N 50358-361-000). The CDI uses the rear coil hole and a 1/4" / 6mm hole drilled thru the crossbar. The "before' setup on the left used the new coil mount for grounding which relied on additional bolts and metal-metal contact, so I wired it direct to the frame bracket along with the main wiring-harness ground (these can also be connected together). Once the coil was out of the way there was room for the CDI box, and the plug lead has a smooth arc to the plug without much bending. This setup has been working great for years.
Author:  Ratmuss [ Mon Feb 02, 2015 8:20 pm ]
Hey guys, all good info- but nothing helps like a an actual install photo. On an actual elsinore would be great too. Or email it to me.
Thanks!
Matt.
Author:  hx35w [ Fri Feb 13, 2015 2:40 pm ]
Not sure how the 73-74 differs from my 76 but if this helps, COOL
Author:  hx35w [ Fri Feb 13, 2015 2:49 pm ]
Try that picture again
Author:  Ratmuss [ Thu Feb 19, 2015 5:55 pm ]
I could have machined brackets and all sorts of garbage, but I wanted to keep it super simple. I used the coil bracket as my starting point, I threaded a longer than needed bolt through the coil side leaving a stud to attach the CDI (these pictures were just a mock up). I then a collar to space it about an 1/8 of an inch away from the bracket, added a washer, rubber grommet then tightend it down. I checked tank clearence and there is plenty. Buttoned it up and went racing this weekend- performed flawlessly- easier starting and no more points to deal with.
