It is currently Sat Aug 02, 2025 7:04 pm
PostPosted: Mon Jan 26, 2015 3:47 pm
Hello, question I have a 1979 Honda CR 250 and would like to put a EXCEL wheels on it, I have found rims in 21x1.60 front, and 18x2.50 rear both 36 hole and I'm wondering if they will work on my bike has anybody done this?
PostPosted: Fri Feb 06, 2015 2:27 pm
I went through the same thing except on a 83 CR480. I had never laced a wheel.
Couldn't find any "conversion" numbers or information, that would let me save some money by buying on the free market. I wasn't paying 200+ bux per rim. That was not in the budget!
I finally went with Tom at Full Circle Racing. 2/3rds the cost of Buchannons Excells, plus Buchannons do not have gold Excells.
Good guy to deal with.
83 CR250
83 CR480
87 YZ250
88 CR250
74 TY250
07 YZ250
83 RM250 on the resto table
91 YZ250 with an Ohlins 360 kit in resto que
83 CR125 in resto que
PostPosted: Tue Feb 10, 2015 11:53 am
if you buy usual ready drilled rims you will get problems.
these rims are made for modern bikes with a small hub diameter, they do not match to the old drumbrake hubs.
the spoke angle is different. and often the nipple dia. is larger.
an undrilled rim has to be fitted to your hub.
i have made this experience.
and a wider rear rim gives you no advantage to the original 2.15 size.
PostPosted: Tue Apr 07, 2015 9:17 am
I got an Excel front rim and had it laced with heavy-weight spokes using Anaheim Wheel Works. Been bullet-proof. I would say this is something you want to have done for you, if only to address the potential need to drill the rim.
