It is currently Sat Jul 05, 2025 12:15 am
PostPosted: Thu Jun 04, 2015 1:41 pm
No one seems to have a replacement foam filter element for my '77 MR175. So I want to make one out of K&N foam airfilter sheets. Does anyone know what type of glue I should use? Will common contact cement work?
PostPosted: Thu Jun 04, 2015 3:10 pm
Try contacting the guy in the link below (dabbernz) through eBay - he sells quite a few UNI MR175 filters (p/n NU 4026), as UNI Australia still makes them. Sometimes he may be out of stock for a bit, but he always seems to get more, and IIRC shipping time is 10-14 days. These are really nice filters with a foam sealing strip added around the bottom, in case the airbox foam gasket is in bad shape or missing (as it usually is). Apparently he can also get the filter frames.
http://www.ebay.com/itm/Honda-MR175-197 ... ee&vxp=mtr
I'm not sure what type of adhesive they use on filter foam, but if applied correctly it's really durable - maybe something like weatherstripping or plastic cement? Some of them seem to have heat-welded seams as well.
PostPosted: Fri Jun 05, 2015 7:30 am
Thanks Ray.
IJ
PostPosted: Thu Jun 25, 2015 5:40 pm
I tried all sorts of glue but gorilla glue, didn't think of it at the time, so I ended up stiching the filter together.
This was for a wrap for a K&N so a minor leak won't matter but if you take your time...
Users browsing this forum: Google [Bot] and 29 guests
