MR tank on CR
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4502
Author:  diesel digger [ Sat Jun 27, 2015 7:34 am ]
Post subject:  MR tank on CR
Will the higher capacity MR 250 or 175 tank fit on my 74 CR125? Wouldn't mind being able to temporarily switch them out when going on a long ride.
thanks, Brad
Author:  rayivers [ Sat Jun 27, 2015 9:24 am ]
Post subject:  Re: MR tank on CR
I believe I fit my '74 CR125 tank to my MR175 frame at one point, so I'm almost certain the tanks can be swapped (don't know about the MR250). I'd be a little concerned about the fork tubes hitting the wider MR tank, as this is sometimes a problem in the MR frame. The CR seat is narrower than the MR tank too.
Author:  diesel digger [ Tue Jun 30, 2015 7:10 am ]
Does anyone know if the bigger MR 250 tank will fit?
Author:  evelmike [ Tue Jun 30, 2015 5:34 pm ]
Try contacting Clarke manufacturing. They have all kinds of tanks including larger capacity.They also have universal tanks. I bet if you give them a call they can answer your question.
