It is currently Sat Jul 05, 2025 3:13 pm
 Post subject: MR tank on CR
PostPosted: Sat Jun 27, 2015 7:34 am
Will the higher capacity MR 250 or 175 tank fit on my 74 CR125? Wouldn't mind being able to temporarily switch them out when going on a long ride.
thanks, Brad
 Post subject: Re: MR tank on CR
PostPosted: Sat Jun 27, 2015 9:24 am
I believe I fit my '74 CR125 tank to my MR175 frame at one point, so I'm almost certain the tanks can be swapped (don't know about the MR250). I'd be a little concerned about the fork tubes hitting the wider MR tank, as this is sometimes a problem in the MR frame. The CR seat is narrower than the MR tank too.
PostPosted: Tue Jun 30, 2015 7:10 am
Does anyone know if the bigger MR 250 tank will fit?
PostPosted: Tue Jun 30, 2015 5:34 pm
Try contacting Clarke manufacturing. They have all kinds of tanks including larger capacity.They also have universal tanks. I bet if you give them a call they can answer your question.
Users browsing this forum: Google [Bot] and 29 guests
