Ray, I looked at the pilot jets this morning. With my eagle eye, looking carefuly the hole size with both jets side by side, I can see that the 38mm #50 jet is smaller thant the wrong #55 I bought this week. But the wrong #55 look the same size that the one in the carb. So from eye checking it look to be the right pilot size, a #55.
The thottle piston is a #3.5.
About the needle, the one in the carb as the number 271303. I have a new one with number 042 (see picture).
The size of the needle are:
271303: straight part 2.41mm lower - taper part 1.77mm
042: straight part 2.50mm lower - taper part 2.12mm
I noticed that I bought BR9ES spark plug and the manual said B9EV. I don't think it can make a big difference... ?
I begining to think that it can maybe be a timing problem. I never checked the timing with a timing light. I only aligned the marks of the stator and the crankcase. As long as I remember, 40 years ago, I never had to check the timing with the timing light. What do you think?
I did some tests with for the float level. I removed the carb from the bike, removed the bowl, I put some cleaner in a temporary fuel tank and measure when the fuel start to flow. At 20mm, there's no flow, the valve is closed. It start to flow at around 22mm.
Do you think this is enough to go out of gas? Can 2mm on the float level can make a big difference like that? Enough for the bike starting and idle fine but not running properly?
