It is currently Sun Aug 17, 2025 8:00 am
 Post subject: Lower Roller on 78 CR250
PostPosted: Mon Dec 20, 2004 4:36 pm
What's the solution for the lower chain roller behind the footpeg? I got a Red-Racer roller and the recess wasn't deep enough and I had to grind the head off the bolt to get it to clear the brake arm and then it blew apart in 2 motos. What else works out there?
PostPosted: Mon Dec 20, 2004 6:09 pm
The Red Racer and OEM rollers use a recessed allen bolt that when installed is flush with the outside edge of the roller. Is this what you used? If not, I'll get you the part # for the correct one. BTW, if you are using an after-market swing arm, it will pinch the chain against the stock-sized roller. That issue is handled in a thread over on the Red Racer forum.
PostPosted: Mon Dec 20, 2004 9:12 pm
Couldn't source the flat allen head bolt, so had to go with the next best thing. Would be interested in bolts, tell me how to get them. I'm using a stock swingarm. I'm familiar with the fox arms and the cool extension they offered. Thanks for the info.
PostPosted: Tue Dec 21, 2004 2:49 pm
Go to http://www.cmsnl.com and search for part # 90124-430-700. Costs Euro 7.50. You could try http://www.westernhillshonda.com and/or http://www.powersportspro.com but I think it is a discontinued part.
 Post subject: 79 Lower Chain Roller
PostPosted: Thu Dec 23, 2004 6:31 pm
Thanks for the info. I ordered from Classic Motorcycle.
Users browsing this forum: No registered users and 6 guests
