Lower Roller on 78 CR250
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=462
Author:  hump@evovintage [ Mon Dec 20, 2004 4:36 pm ]
Post subject:  Lower Roller on 78 CR250
What's the solution for the lower chain roller behind the footpeg? I got a Red-Racer roller and the recess wasn't deep enough and I had to grind the head off the bolt to get it to clear the brake arm and then it blew apart in 2 motos. What else works out there?
Author:  redrocket190 [ Mon Dec 20, 2004 6:09 pm ]
The Red Racer and OEM rollers use a recessed allen bolt that when installed is flush with the outside edge of the roller. Is this what you used? If not, I'll get you the part # for the correct one. BTW, if you are using an after-market swing arm, it will pinch the chain against the stock-sized roller. That issue is handled in a thread over on the Red Racer forum.
Author:  Guest [ Mon Dec 20, 2004 9:12 pm ]
Couldn't source the flat allen head bolt, so had to go with the next best thing. Would be interested in bolts, tell me how to get them. I'm using a stock swingarm. I'm familiar with the fox arms and the cool extension they offered. Thanks for the info.
Author:  redrocket190 [ Tue Dec 21, 2004 2:49 pm ]
Go to http://www.cmsnl.com and search for part # 90124-430-700. Costs Euro 7.50. You could try http://www.westernhillshonda.com and/or http://www.powersportspro.com but I think it is a discontinued part.
Author:  hooskie17 [ Thu Dec 23, 2004 6:31 pm ]
Post subject:  79 Lower Chain Roller
Thanks for the info. I ordered from Classic Motorcycle.
