MT upgrade https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4655 |
Author: | Dave Rawlings [ Thu Jun 23, 2016 4:10 am ] |
Post subject: | MT upgrade |
![]() Kind regards Dave. |
Author: | rayivers [ Thu Jun 23, 2016 3:04 pm ] |
Post subject: | Re: MT upgrade |
The MT250 injection system basically just sprays oil into the intake manifold, so there's no problem running premix provided the manifold hole is sealed off. I agree about removing the pump too, as without lubrication it will surely self-destruct eventually. Ray |
Author: | Dave Rawlings [ Fri Jun 24, 2016 3:13 am ] |
Thanks Ray I'm going to have a look at it this week end. |
Author: | Dave Rawlings [ Sat Jun 25, 2016 1:32 am ] |
Author: | rayivers [ Sun Jun 26, 2016 6:55 pm ] |
I've never done it myself, but it should be possible to connect the 6V lighting coil and 6V charging coil together in series, ending up with a higher (possibly much higher) single voltage with the current capacity of the charging-coil winding. You may have to experiment with different connection polarities to get a voltage close to what you want. You could try calling CycleColor and Marbles Motors to see what they have in the way of Honda Elsinore paints. There used to be a place that sold aerosol cans of the CR silver and green paints, and of course there's always the Preval sprayers if you can find the paint you want in pints/quarts etc. If you're not concerned with getting a finish like OEM, I've gotten some very good results using DupliColor auto paint. Ray |
