It is currently Sun Aug 17, 2025 12:18 pm
 Post subject: 74 CR125 air boot woes
PostPosted: Mon Jul 04, 2016 5:33 pm
Hello,
I bought a new Mikuni VM30-83, since the Mikuni carb that came on my bike was not responding as expected to jetting changes and had a 50mm inlet bell and poor fitting "straight" air boot (this boot lacked the height change from inlet bell to air filter cage). I am unable to mate the new carb-mating air boot to my air filter cage. The boot fits the 58mm carb inlet bell fine, but has a 78mm diameter where it meets the air filter cage. This is just small enough to not fit the 80mm air filter cage.
I have not yet tried a hair dryer to stretch the boot to the wider opening, although the boot is soft and pliable.
Have I got the wrong boot or a non-original air filter cage?
Can a dremmel tool be used to remove some carb boot rubber to make it fit?
UPDATE: the air filter cage opening of the boot that came on the bike as well as a new boot fitting a 26mm Mikuni (46mm air inlet bell) both measure 78mm. The new boot should stretch to fit the air cage.
Thank you,
Ben
PostPosted: Mon Jul 04, 2016 7:36 pm
The CR125M air boots fit the air filter cage flange very tightly, by design. You will probably need heat and a fair amount of stretching to get the boot on the cage, but once it's on and the clamp's in place it's not going anywhere unless it rips.
The Honda 17253-400-000 and Suzuki 13881-41301 air boots both have 57mm carb-side and 76mm airbox-side openings and @ 75mm overall length, plus an upward offset from carb to airbox.
PostPosted: Tue Jul 05, 2016 2:53 am
Thank you, Ray.
Users browsing this forum: Bing [Bot], Google [Bot] and 40 guests
