MT250 Flywheel puller
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4703
Author:  MT250GUY [ Sat Nov 12, 2016 5:55 am ]
Post subject:  MT250 Flywheel puller
I assume any puller for this bike is going to consist of two pieces. One hollow 20 mm threaded collar and a bolt that threads into the collar to torque on to "pop" the flywheel off. It appears a BikeMaster - 150604/MP7 is correct, but every depiction of the tool only shows the collar and not a bolt that threads on it.
Confused noob!
Author:  rayivers [ Sat Nov 12, 2016 7:19 am ]
Post subject:  Re: MT250 Flywheel puller
The Honda MT250 07933-3580000 flywheel puller (shown on page 92 of the shop manual) has been superceded by the 07933-3950000 MR250 puller in the link below. It's a T-handle outer-threaded tube which pushes against the end of the crank (no bolt).
http://www.ebay.com/itm/Honda-07933-395 ... rZ&vxp=mtr
Here's another one, without the T-handle (which should allow much more torque to be applied):
http://www.ebay.com/itm/20mm-PULLER-TOO ... 09&vxp=mtr
Author:  MT250GUY [ Sun Nov 13, 2016 9:23 am ]
Thanks Ray. Ordered it.
