Honda mt250 carb
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4713
Author:  merc47 [ Tue Dec 06, 2016 12:48 pm ]
Post subject:  Honda mt250 carb
I have a 74 mt250 I cant find any info what size of 0 ring is used on the float bowl drain plug on the left side, And is there any other carb that is a replacement and will bolt up.
Author:  rayivers [ Wed Dec 07, 2016 10:06 am ]
Post subject:  Re: Honda mt250 carb
If you have the stock carb (with the large drain plug on the bottom of the float bowl), a Honda 91302-KE8-003 O-ring works well.
Early CR125M and all MR175 carbs are nearly identical to the OEM MT250 carb and fit perfectly. A new Keihin PE28 carb should work, but will need an adaptor for the airbox end.
