79 CR125 front hub
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4715
Author:  diesel digger [ Tue Dec 13, 2016 8:42 am ]
Post subject:  79 CR125 front hub
Wanting to switch to a 21" front wheel. I have some 16.5" remote res Ohlins to lower the rear.
Could i relace the 79 125 hub with 78-80 250 spokes and matching rim? Is the 1980 125 hub and brake panel the same as the 1979?
Thanks, Brad
Author:  spannerman167 [ Fri Dec 16, 2016 1:09 pm ]
Post subject:  Re: 79 CR125 front hub
Yes 1980 CR125 the same as is the 78 - 80 CR250
Author:  diesel digger [ Fri Dec 16, 2016 11:08 pm ]
Thanks. Is the 79 125 hub the same as well?
Author:  tnr [ Sun Jan 22, 2017 10:41 pm ]
79-81 CR125's use the same part # front hub. You would need a spoke set from an 80-81.
