Cr stator and flywheel in Mt?
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4719
Author:  BriceB [ Thu Dec 15, 2016 9:33 am ]
Post subject:  Cr stator and flywheel in Mt?
Hi I have a 1974 mt125 engine that I have put on a 1974 cr125 frame. The cr frame still has its oringinal magneto and the electrical box thing. The mt stator and flywheel don't seem to be working so I was wondering if I could put a cr flywheel and stator? Thank you
Author:  rayivers [ Thu Dec 15, 2016 2:57 pm ]
Post subject:  Re: Cr stator and flywheel in Mt?
As long as the MT and CR crank keyways are in exactly the same position, it should work. The '74 CR rotor is designed to be held on with a bolt and not a nut like the MT flywheel, but the nut should work fine with a washer underneath it.
