Looking to validate bearing #s
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4738
Author:  jsjamboree [ Tue Feb 14, 2017 9:52 am ]
Post subject:  Looking to validate bearing #s
Hey guys, new to the forum, building up an MT250. Need to replace the the right small countershaft bearings and the left crank bearing. Looking on CMSNL im not confident I have the right part numbers. Hoping someone can make sure im on point before i spend the money.
Left Crank Bearing
    961026306300, doesn't have the listing for the left, so im assuming L and R are the same
Right Small Prop Bearing
    91005mg3003
Thanks!
Pic Image
Author:  rayivers [ Tue Feb 14, 2017 7:03 pm ]
Post subject:  Re: Looking to validate bearing #s
Your part numbers are correct for the MT250 96102- LH and RH crankshaft bearings and the 91005- RH countershaft bearing.
Author:  Rustynutz [ Tue Feb 14, 2017 7:07 pm ]
check out boss bearings, same as CR250
