It is currently Sun Jul 13, 2025 6:13 pm
PostPosted: Thu Mar 09, 2017 7:03 am
Has anyone tried to put a stock 74/75 CR125 down pipe on an MR175?
I think the MR 175 exhaust manifold exits at a slightly different angle than the CR125 but that can be overcome.
A problem with clearances under the engine or below the footpeg would be more challenging.
Thanks.
Mark
PostPosted: Thu Mar 09, 2017 9:25 am
It can be done, but you'll need to do 3 things first:
1) Re-angle the inlet flange, as you mentioned
2) Remove the skid plate (duh), then
3) Replace the brake pedal return spring holder on the frame with an M8 threaded hole for the rear pipe mount
If you get creative, you can hold on the pipe and the spring with the same bolt/nut. :)
Here's a link to some '75 'CR175' pics, which show the bolt in 3) above:
http://www.wischt.com/machine/MEP-CR175
PostPosted: Fri Mar 10, 2017 1:32 pm
Great. Thank you Ray!
