Burned out light bulb
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=4772
Author:  Gokyo [ Sun Apr 30, 2017 9:14 pm ]
Post subject:  Burned out light bulb
I have a brand new battery.
brand new bulb burned out on just about the first use?
Any suggestions?
Author:  Gokyo [ Sun Apr 30, 2017 9:39 pm ]
Post subject:  Re: Burned out light bulb
Ok the battery test at 9.3 volts when the bike is running.
I guess this means that the rectifier/regulator is not working?
Any suggestions on getting a new one?
I guess I am wondering if any 6v 4 wire rectifier will work.
WHy did they have to make this motorcycles on a 6v system.
Author:  Rick [ Wed May 03, 2017 10:11 pm ]
Before anyone can even get a chance to anewer your question we need to know what year and model the bike is.
My 1975 Honda mt250 does not have a regulator but uses a resistor hidden behind the headlight bucket. If that has failed or is not there or has a poor connection to it your headlight will burn out immediately when you rev the engine.
Rick
Author:  Gokyo [ Thu May 04, 2017 11:44 pm ]
It is a 1974 mt 250.
It has a big green resistor attached to the light bulb with a white wire.
I guess I could try to check resistor.
Any chance you know how to test the resistor?
Author:  Gokyo [ Sat May 06, 2017 5:51 pm ]
my resistor measures 3.2 ohms?
