fork oil for 1979 cr125 elsinore
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=484
Author:  GomerPile2525 [ Mon Jan 03, 2005 11:35 am ]
Post subject:  fork oil for 1979 cr125 elsinore
how much do i put in? how much? and will 30 wt oil work good in them?
Author:  redrocket190 [ Mon Jan 03, 2005 11:38 am ]
I would be surprised if you want to use anything heavier than ATF or 10-weight...
Author:  GomerPile2525 [ Mon Jan 03, 2005 10:46 pm ]
how much do i put in? 4 oz?
Author:  redrocket190 [ Mon Jan 03, 2005 11:11 pm ]
Sorry I just don't know, you will have to hope someone with the 125 speaks up. (The figures for a CR250R 1979 are 205 cc if you pump the forks out, and 275 cc if you re-fill them dry.)
Author:  Vintage Elsinores [ Tue Jan 04, 2005 4:32 pm ]
Hey Gomer,
If you drained the fork tubes only, you'll need to replace it with 9.6oz or 285cc of oil in each leg. Now if you completely torn them down and cleaned them and they are dry, you'll need to refill it with 10ozs or 295cc of oil in each leg. Okay now they came with 5W fork oil in them, so 10W is okay, but I would not advise on 30W unless you weighed 460 lbs, and in that case I would suggest a CR480. ThatÃŒs what I use to get my big ass around the track. I hope this helped? :mrgreen:
Author:  redrocket190 [ Tue Jan 04, 2005 5:29 pm ]
Don, what fork and shock setup are you running on the CR480R? I am 180lbs before the gear goes on and my fat ass is round the front. :D
Author:  GomerPile2525 [ Wed Jan 05, 2005 7:43 pm ]
ok guys this is wat i did... i put 8oz of 30wt oil in eat leg and its perfect! i weight 220 pounds and do some pretty hard trail riding.. so thats that
Author:  J [ Wed Jan 05, 2005 11:18 pm ]
30 wt hydraulic oil?
J
Author:  GomerPile2525 [ Thu Jan 06, 2005 12:22 am ]
i dont know.. all i know is its fork oil from the dealer
Author:  Vintage Elsinores [ Thu Jan 06, 2005 9:19 pm ]
BEL-RAY maybe?
Author:  GomerPile2525 [ Thu Jan 06, 2005 10:32 pm ]
no its some chineese name like sinkoline or soemthing like that
Author:  redrocket190 [ Fri Jan 07, 2005 11:51 am ]
Silkolene maybe? :shock:
Author:  Vintage Elsinores [ Fri Jan 07, 2005 5:39 pm ]
Last time I checked Silkolene was pretty good oil, and I wouldn't refer to it as cheesy? :shock: :mrgreen:
Author:  GomerPile2525 [ Fri Jan 07, 2005 10:45 pm ]
yea i got it from the honda dealer :lol:
