It is currently Sun Aug 17, 2025 10:00 am
PostPosted: Sat Jan 08, 2005 5:11 pm
Which carb works best and what intake boot (79 or 80) should be used? Thanks!
J
#829 The "Factory Novice"
1988 Honda CR250RJ
1983 Honda CR480
1981 Can-Am 250 MX6-B
1979 Honda CR250RZ
1979 Kawasaki KX250 A5
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
PostPosted: Wed Jan 12, 2005 2:57 pm
Hey J,
Both carburetors work great on the 125RÌs. You donÌt have to worry about the manifolds, because both carbs are from the same body. So the OD that fits into the manifold is the same. The only thing is the 32mm is 102mm from front to back, and the 34mm is 93mm front to back, and the stocker is 93mm as well. But IÌve use both carbs on bikes IÌve built for customers, the only thing is if you use the 34mm you might want to do some work on the head to give the bike a little more bottom end, do to the fact that youÌll loose some of that stepping up to a larger carb. If you go for the 32mm you wonÌt have to do anything really, unless you want to shave down the bell to 93mm which will increase the bottom a little. Hope this helps.:mrgreen:
Don Brooks
Vintage Elsinores
Ventura, CA.
http://www.elsinores.com
PostPosted: Wed Jan 12, 2005 5:42 pm
Thanks Donnie B !
I have one of your 32mm carbs and a ProForm pipe I'm finally getting around to installing. It should have decent bottom (for a 125) and great mid-range. :D
J
1988 Honda CR250RJ
1983 Honda CR480
1979 Honda CR250RZ
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
PostPosted: Wed Jan 12, 2005 8:34 pm
And gobs of top end as well, in fact your bike should scream like a red headed stepchild!:mrgreen:
Don Brooks
Vintage Elsinores
Ventura, CA.
