bike smoking https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=505 |
Author: | Guest [ Thu Jan 13, 2005 1:47 pm ] |
Post subject: | bike smoking |
well guys i think something is wrong with my bike... when im in the corner and i pop the clutch in 1st gear the bike smokes really bad untill i let go of the throttle... but when i dont pop the clutch it doesnt smoke that bad.. i am running 40:1 ratio with yamalube and its mixed perfectly. i dont know wats wrong with it? is it the jetting or wat? |
Author: | CR250Ryan [ Thu Jan 13, 2005 6:30 pm ] |
Post subject: | |
I usually use second gear coming out of corners, so you may be over revving it. Could also be a worn out top end... |
Author: | GomerPile2525 [ Thu Jan 13, 2005 7:46 pm ] |
Post subject: | |
well i do use 2nd gear alot too but wat im trying to say is like a start at a race..u know how u pop the clutch.. it smokes badly |
Author: | CR250Ryan [ Thu Jan 13, 2005 7:50 pm ] |
Post subject: | |
could be jetting, or worn carb parts. what bike are you talking about? |
Author: | GomerPile2525 [ Fri Jan 14, 2005 10:18 am ] |
Post subject: | |
sorry the guest post is me.. its my 1979 cr125 |
Author: | CR250Ryan [ Fri Jan 14, 2005 11:34 am ] |
Post subject: | |
i suppose your idle circuit could be rich, since you experience the smoking when you take off real quick... maybe adjust the air screw. |
Author: | gear lube [ Fri Jan 14, 2005 6:54 pm ] |
Post subject: | |
it needs new crank seals |
Author: | GomerPile2525 [ Sat Jan 15, 2005 9:44 pm ] |
Post subject: | |
where can i get crank seals |
Author: | Rick [ Fri Jan 28, 2005 9:26 am ] |
Post subject: | |
I agree. Right side crank seal. Replace both. You may have to split the cases to change the right side. ![]() You can get these almost anywhere. Try http://elsinores.com/ or any seal shop or good bike shop. |
