It is currently Fri Jul 04, 2025 12:33 pm
 Post subject: bike smoking
PostPosted: Thu Jan 13, 2005 1:47 pm
well guys i think something is wrong with my bike... when im in the corner and i pop the clutch in 1st gear the bike smokes really bad untill i let go of the throttle... but when i dont pop the clutch it doesnt smoke that bad.. i am running 40:1 ratio with yamalube and its mixed perfectly. i dont know wats wrong with it? is it the jetting or wat?
PostPosted: Thu Jan 13, 2005 6:30 pm
I usually use second gear coming out of corners, so you may be over revving it. Could also be a worn out top end...
1980 CR250R Elsinore
PostPosted: Thu Jan 13, 2005 7:46 pm
well i do use 2nd gear alot too but wat im trying to say is like a start at a race..u know how u pop the clutch.. it smokes badly
PostPosted: Thu Jan 13, 2005 7:50 pm
could be jetting, or worn carb parts. what bike are you talking about?
PostPosted: Fri Jan 14, 2005 10:18 am
sorry the guest post is me.. its my 1979 cr125
PostPosted: Fri Jan 14, 2005 11:34 am
i suppose your idle circuit could be rich, since you experience the smoking when you take off real quick... maybe adjust the air screw.
PostPosted: Fri Jan 14, 2005 6:54 pm
it needs new crank seals
PostPosted: Sat Jan 15, 2005 9:44 pm
where can i get crank seals
PostPosted: Fri Jan 28, 2005 9:26 am
I agree. Right side crank seal. Replace both. You may have to split the cases to change the right side. :(
You can get these almost anywhere.
Try
http://elsinores.com/
or any seal shop or good bike shop.
