It is currently Sat Jul 05, 2025 12:03 am
PostPosted: Thu Feb 10, 2005 7:32 pm
Does anyone have any info concerning the flywheel puller for these models? I have looked everywhere and am having no luck at all. I took the bottom end to my local Honda shop, and they had nothing to fit. It seems the flywheel is beefy enough to survive using a generic craftsman flywheel puller through the holes in the back, but just not sure.
Honda CR250R Elsinore 1980
Honda CR250R Elsinore 1978
Honda CR125 Elsinore 1974
Honda CR250 Elsinore 1973
Suzuki RM370 1977
Yamaha YZ465 1980
Yamaha YZ125 1983
PostPosted: Sat Feb 12, 2005 1:18 pm
To precis a longer thread from the Red Racer board. You need Honda # 07933-KG2-0000. The original puller was 07933-430-0000 but this is discontinued.
PostPosted: Sat Feb 12, 2005 5:33 pm
Site Admin
Check this out:
http://www.repairmanual.com/motorcycles ... 4/99/10456
PostPosted: Sat Feb 12, 2005 6:01 pm
Looks perfect. Move this to CR reference?
PostPosted: Sat Feb 12, 2005 7:44 pm
Unfortunately, the threads on this flywheel require a 'female' puller, not a 'male' puller. The puller Nathan references is a 'male' puller, and while it indeed says it's a puller for the 250R, it is not correct. That puller works fine on a 74 CR125 for instance, where the flywheel mounts in a traditional position and the threads on the flywheel are internal, and accept a 'male' puller.
However, on the 78-90 250R, the flywheel mounts backwards, and the threads are 'external' and require 'female' puller, and that has been my problem. They are not easy at all to find. Indeed, my local Honda shop had over 40 pullers, but not one fit that flywheel.
Michael, thanks for the info. I'll check out the puller you listed with my local dealer.
Suzuki RM370 1977
Yamaha YZ465 1980
Yamaha YZ125 1983
