NEED HELP! my bike wont run!
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=532
Author:  76mt250 [ Sun Jan 30, 2005 6:40 pm ]
Post subject:  NEED HELP! my bike wont run!
alright i was goin for a pit ride this summer when duhhhhhhmmmm bike dies. i lost all spark! then it suddnely starts running and keeps on dying theres new plugs in it my points look alright i dont know about my coil tjo was my bike supposed to have 2 plugs?
Author:  ricortes [ Mon Jan 31, 2005 12:13 pm ]
Just to make sure I would sand the points and maybe replace the condensor. I have checked what looked to be good points for closure using a DVM and found they weren't closing reliably. I've also had points go out due to a bad condensor letting them oxidize and stop making contact.
Author:  wholman [ Mon Jan 31, 2005 1:09 pm ]
Post subject:  bike won't run
you don't have two spark plugs, the side one should have a plug in it and put the sparkplum in the middle for consitancey
Author:  Guest [ Mon Jan 31, 2005 8:43 pm ]
so is my biek supposed to have 2 plugs if so were the do i find a duel coil that would work?? like can i jerry rig a twin bike coil to it?
Author:  Guest [ Thu Feb 03, 2005 6:48 pm ]
Some keep a spare plug in the second hole. It can also be used to install a compression release. The bike came with a spark plug fitted in the hole on the top center. The other hole was plugged with short bolt. The coil should connect only to one plug at a time. You might need a new coil. By the way, you can not remove the primary wire without breaking it.
I had my bike stop on me last summer. After checking the points, I removed the tank and found the wire connecting the coil to the points slipped out of its connection. I tighten the connection slightly with some pliers and plugged it back in. Has worked fine since. Trace your wires and connections.
