It is currently Fri Jul 04, 2025 10:38 pm
 Post subject: CR250 Footpegs
PostPosted: Sat Jan 22, 2005 8:35 pm
Are wide footpegs available for the 1978-80 CR250? I have heard that 1995 CR pegs work with modification, but I'm not too sure. I have seen some post that they have IMS pegs, but I have not been able to find them.
For those that care, I have found the wide footpegs available for the XR50/CRF50 fit perfectly on my 74 CR125.
Honda CR250R Elsinore 1980
Honda CR250R Elsinore 1978
Honda CR125 Elsinore 1974
Honda CR250 Elsinore 1973
Suzuki RM370 1977
Yamaha YZ465 1980
Yamaha YZ125 1983
PostPosted: Sun Jan 23, 2005 9:56 am
Site Admin
I have modified IMS pegs on one of my '79 CR250R's and I like the pegs, but hate the decreased space between the front of the peg and shift lever. It makes it very easy to accidently shift out of the gear you're in, expecially when you're going through whoops or when you're in the air. I've been trying to find a shift lever that is longer than the stock lever. That would fix the problem. If you know of one, let me know.
PostPosted: Sun Jan 23, 2005 4:02 pm
I too have modified IMS pegs and love them. Even with the stock pegs the gear lever is a bit tight. The only solution I have heard of is to buy a after-market lever that fits the shaft and the weld and extension in the middle...
PostPosted: Mon Jan 24, 2005 12:59 pm
I put 2003 CRF450 footpegs on my '79 CR250. I bought them on ebay for about $30. You do have to remove some material to make them fit. If you're careful you can shape them so they have a fold-up stop surface. I used 2000/01 CR250 footpeg springs (flipped around and trimmed- about $2.75 each).
The 2003 CRF450 pegs sit lower than the 2000/01 CR pegs which helps shifting. A dremel with a cutting wheel, and a belt sander made the job a breeze. Remove material slowly so they fit right.
 Post subject: Foot pegs
PostPosted: Thu Jan 27, 2005 7:33 pm
I've tried later model pegs. They tend to droop after riding hard. What I used this past season was the stock pegs properly cut and fitted. Buy WP foot peg wideners and cut out enough material to fit in wideners. You can then weld both sides. I have had no problem through a full season. You still have to lengthen your shifter. I buy a Moose 11 or 13 shift lever. I then cut and straighten out the lever. Make the lever approximately 5.5" from the peg. Hope this helps.
PostPosted: Fri Feb 11, 2005 3:17 pm
I know vintage iron http://www.vintageiron.com/ has replacement, wide footpegs available for 100+ dollars. They also list some weld on for about $35. Has anyone installed either of these on their 250? :?:
PostPosted: Fri Feb 11, 2005 4:44 pm
On my 73 CR250 I took a couple of pieces of 1.5" band steel, wrapped them around the stock foot pegs raised the peg height about .5" and extended them out about 1.5" inches and welded them on.
Loren Davis
51y
