http://www.vpracingfuels.com/ is a provider of gas that performs better than what you can get from the pump at your local gas station. And they have something for everyone from a top fuel dragster to our humble historic motocross bikes. (Very!) simply put they provide gas with a higher octane rating to prevent detonation in engines with more compression (power) and/or a higher oxygen content so the fuel generates more energy (power) when combusted.
C12
The best all around racing fuel made. Recommended for CRs below 15:1, satisfying the needs of 75% of today's race engines.
• Color: Green
• Motor Octane: 108
‚Ä¢ Specific gravity: .717 at 60¬? F
This particular blend is a
leaded fuel that you cannot buy at the gas station. Note the 108 octane which is reduced when it is blended with regular 91 octane pump gas, but the end result is still better but a little more economical. Unless you modify your engine to the point that you need 104+ octane to prevent it blowing up, this is choice. I found (perceived?) that my bike ran cleaner with it so I make the investment, but mix it to be a little economical. Also this stuff really stinks so don't get it all over the garage floor etc. It will go "off" if left for weeks in your gas tank so it is best to mix just what you need for a specific ride/race and afterwards drain the remainder back into a metal can.
