1973 mt250 ignition coil problems...possible solution
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=567
Author:  jad1682 [ Mon Feb 28, 2005 9:04 pm ]
Post subject:  1973 mt250 ignition coil problems...possible solution
Ok Im pretty sure Im a victim of a bad ignition coil, (im getting very weak spark not enough to cause combustion) my question is do you think a 6 volt ignition coil for an old automobile would work to replace the stock coil
Author:  ricortes [ Tue Mar 01, 2005 1:37 pm ]
What I did was use a 6V motorcycle coil from J.C. Whitney on an XR75. The XR had previously had a MT coil on it for a few days so it implies the 6V coild would have worked on the MT. The mounting for none of them line up of course.
It may be a better fit if you get a coil out of any XL except the 175, an XR pre CDI like 73 XR75. I believe the coils are actually labeled ~6VAC impling they are an AC coil. The 175XL and most of the street bikes like 125SL or CB used DC coils.
