It is currently Tue Jul 01, 2025 7:18 am
PostPosted: Mon Apr 07, 2003 4:31 pm
I have a problem because I don't have a manual. I put my two case halves together on my '79 125. I turn the selector drum by hand while turning the sprocket shaft. I can get the drum to turn almost all the way around but at no time can I turn the sprocket shaft. The clutch shaft will not turn as well. There is no neutral. At some point should I not be able to turn the clutch shaft andÜthe sprocket shaft not turn depending on the position of my selector drum of course?
Please get back to me withany kind of help manual or otherwise.
Regards, Lez
PostPosted: Mon Apr 07, 2003 4:32 pm
There is a notch in the drum that is turned a certain way to be put back together, I have several books and manuels if you need help.
