It is currently Fri Jul 04, 2025 7:34 pm
PostPosted: Thu Apr 07, 2005 11:04 am
Does anyone know where I can get a 1980 CR250R NOS OEM piston kit?
I have a original stock chrome bore, and I am told I need an OEM piston, and they don't make them any more.
Dale E White
1980 CR250R
2002 R1
PostPosted: Thu Apr 07, 2005 12:25 pm
Wiseco has all the parts you need to re-build your top-end. There is only one twist. If you have an original chrome bore you use 2756CDM rings, if you have a sleeve you use 2756CD rings, assuming the sleeve has not been bored out. They have over-sized CD rings to go with their larger pistons. But they do not do over-size CDM rings, so it appears that one is forced to go with a sleeve rather than a bore and (chrome) re-plating. I don't believe that Vertex or Pro-X do pistons for this motor...
