It is currently Fri Jul 04, 2025 10:54 pm
 Post subject: CR 250 Reed valves.
PostPosted: Tue Apr 26, 2005 4:28 pm
Guys - can anyone tell me when CR 250's started coming out with Reed valves?
I have one on a 1973 CR 250 (came with the bike) and I am now worried about class eligibility?
thanks
1974 Yamaha YZ360B
1977 Suzuki RM370B
1980 Honda CR250RA
PostPosted: Tue Apr 26, 2005 8:26 pm
I believe that is an allowed upgrade to your 73.
J
#829 The "Factory Novice"
1988 Honda CR250RJ
1983 Honda CR480
1981 Can-Am 250 MX6-B
1979 Honda CR250RZ
1979 Kawasaki KX250 A5
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
PostPosted: Tue Apr 26, 2005 10:34 pm
It is allowable but some push the rules by putting late model reed blocks cut out of newer bike cyclinders on the old elsies. Most get away with it but I hear that if they want to throw the book at...
The bolt on blocks are totally legal as they are of era.
 Post subject: Re: CR 250 Reed valves.
PostPosted: Wed Apr 27, 2005 3:53 pm
It is allowable in AHRMA Sportsman and age classes.
As Rick alluded to if your unit is completely off a later model CR or other make and someone lodges a protest you might be DQ'd. Another way to do it though is to machine your own manifold and reed cage if you have access to a vertical mill. You can use anything you build or have built for you.
Loren
Loren Davis
51y
PostPosted: Thu Apr 28, 2005 4:23 pm
thanks guys - most appreciated
1974 Yamaha YZ360B
1977 Suzuki RM370B
1980 Honda CR250RA
