CR 250 Reed valves.
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=643
Author:  rossvickicampbell [ Tue Apr 26, 2005 4:28 pm ]
Post subject:  CR 250 Reed valves.
Guys - can anyone tell me when CR 250's started coming out with Reed valves?
I have one on a 1973 CR 250 (came with the bike) and I am now worried about class eligibility?
thanks
Author:  J [ Tue Apr 26, 2005 8:26 pm ]
I believe that is an allowed upgrade to your 73.
J
Author:  Rick [ Tue Apr 26, 2005 10:34 pm ]
It is allowable but some push the rules by putting late model reed blocks cut out of newer bike cyclinders on the old elsies. Most get away with it but I hear that if they want to throw the book at...
The bolt on blocks are totally legal as they are of era.
Author:  FirePig [ Wed Apr 27, 2005 3:53 pm ]
Post subject:  Re: CR 250 Reed valves.
It is allowable in AHRMA Sportsman and age classes.
As Rick alluded to if your unit is completely off a later model CR or other make and someone lodges a protest you might be DQ'd. Another way to do it though is to machine your own manifold and reed cage if you have access to a vertical mill. You can use anything you build or have built for you.
Loren
Author:  rossvickicampbell [ Thu Apr 28, 2005 4:23 pm ]
thanks guys - most appreciated
