Fox Shox id/info help! https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=659 |
Author: | j_w [ Mon May 16, 2005 9:40 am ] |
Post subject: | Fox Shox id/info help! |
I was wondering if anybody can tell me about the Fox rear shox (they have remote resivoirs)? I bought the bike and the previous owner could not tell me anything about the shox. Any help would be appreciated!! Thanks...J_W ![]() |
Author: | redrocket190 [ Mon May 16, 2005 3:31 pm ] |
Post subject: | |
They are rarer than Fox Shox air (only) shocks and quite desirable. You will probably make a pretty penny if you sell them. Someone on the swap meet was looking for a pair recently. Also interesting is that it appears that a previous owner has grafted on the Pro-Link swing arm from a later (1981-on) bike and converted it to use twin shocks instead of a linkage. And you have a 1983 43mm Showa front-end but not the twin leading shoe front brake setup... |
Author: | J [ Mon May 16, 2005 4:06 pm ] |
Post subject: | |
J-W, So, you bought Jimmy's bike? I didn't know if he was still selling it. Are you just using the pics as an example or do you really own that bad boy? Michael, Those are Fox Factory Forx without the stickers and it does have a 1981 swigarm that has been modified. It also has the FMF frame modification. Those are the Fox Factory shocks that are similar to Ohlins and the engine has Mugen ME125 kit on it. ![]() J |
Author: | redrocket190 [ Mon May 16, 2005 7:17 pm ] |
Post subject: | |
...should have noticed that the bottom of the fork legs are more square than the Showas. Now I have my glasses on of course I can see that they are actually 44 not 43mm. ![]() |
Author: | j_w [ Tue May 17, 2005 8:33 am ] |
Post subject: | |
Hey Micheal Quote: So, you bought Jimmy's bike? I didn't know if he was still selling it. Are you just using the pics as an example or do you really own that bad boy?
You're right that is Jimmy's bike...I wish I owed the bike but don't. Just using pic so everyone knew what type of rear shox I was talking about. Mine are exactly the same as in the picture...but I'm not sure if they are twin clickers (rebound and dampening adjustments)? ![]() J_W |
Author: | redrocket190 [ Tue May 17, 2005 11:35 am ] |
Post subject: | |
The swing arm is an interesting mod. I have seen a 1979 CR250R with a "twin shock" Pro-Link swing arm and a CR480R engine in the frame. Very sweet bike, raced at last year's VIWC at Glen Helen. |
Author: | LtThor [ Mon May 30, 2005 5:43 am ] |
Post subject: | Fox Factory Shox |
If you need one, I have the Owners Manual that I can copy for you. Also, I offer a seal rebuild kit on my site if you should ever need one in the future. Thor |
Author: | Rhawes [ Fri Jun 03, 2005 5:34 pm ] |
Post subject: | Fox Factory Shoxs |
JW, Those are the well know and highly desired Fox Factory Shox's (as the other gentlemen have stated here); pretty much identical to the Fox Piggy Back Shox's; they share the same internals, shafts and other misc. parts, but the Piggy Backs have an alloy top pivot-eye/cap with a "fixed" reservoir, instead of the remote setup (which makes the P.B.’s "much" easier to mount and less weight). Internally, both use a shim setup for numerous combinations to configure the rebound and compression dampening to the rider’s ability and a verity of track conditions (this is defined in the Fox manual). The Twin-Clicker’s are for single shock bikes and were not made for the pre '80 MX bikes. On another note…what ever became of Jimmy's bike? I wonder if he ever did sell that hot little '79 Mugen ME125; I'll have to give Jimmy a call this weekend to see what’s up. Good luck with your new Fox Shoxs… Robert D. Hawes Jr. Mesa, Arizona |
Author: | tomh. [ Sun Jun 05, 2005 3:31 pm ] |
Post subject: | More Fox Shox Questions? |
Hi. Do you guys have a source for replacement seals for these Fox Shox? How about oil weight and quantity? Air pressure (or Nitrogen)? And how do they come apart? Looks like a plastic cover over the seal? Standard threaded seal head under that? |
Author: | Rhawes [ Mon Jun 06, 2005 11:25 am ] |
Post subject: | Fox Seals... |
Hello, You can get seal kits and a copy of the manual from Fox...(831) 274-6500 was the last number I had for them. Take care, Robert |
Author: | crc515 [ Tue Jun 07, 2005 11:00 am ] |
Post subject: | Re: Fox Seals... |
Hi, I also have a pair of these Fox shocks, but one shaft is slightly bent. Anyone know of a place to get shafts, or has anyone had any luck having them straightened? |
