It is currently Sat Jul 05, 2025 12:59 am
PostPosted: Sun Aug 14, 2005 6:46 pm
Hello,
Can someone tell me what aftermarket shifters (folding)work best with the 79 CR 250?
I plan on installing wider footpegs from a CR 450 so please keep this in mind when suggesting options.
Thanks for the space,
Paul
PostPosted: Mon Aug 15, 2005 8:36 am
This comes up pretty regularly. It seems you will not find a folding shift lever for this particularly bike. However you can find levers that will fit the splines on the shift shaft - a 1983 CR480R was one that was mentioned. You then need to bend and cut the lever to fit. I rode at the weekend on a 1979 CR250R that had what looked like a straight Moose folding lever that had been cut to size and re-welded. It was easier to use than the stock lever on my bike. Of course if you put the wider pegs on first you can make it work specifically for them...
Users browsing this forum: Majestic-12 [Bot] and 42 guests
