73 CR250M Crankshaft
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=763
Author:  Scrappy [ Sat Sep 03, 2005 9:54 pm ]
Post subject:  73 CR250M Crankshaft
I am rebuilding a 1973 CR250M motor. Is there an aftermarket crank kit available for this motor? like a wiseco or other. Thanks. :)
Author:  Elsinore1 [ Wed Sep 07, 2005 2:34 pm ]
Try Vintage Elsinore.com
Author:  Rick [ Mon Sep 12, 2005 12:19 am ]
Crank Works in Tempe Arizona can put in a later rod kit and balance it for you. I had mine done and it has so much less vibration. Be sure to send your new piston/rings/... everything on the top end so they can balance it correctly.
Author:  Vintage Elsinores [ Tue Sep 13, 2005 5:49 pm ]
Hey Scrappy,
We have a complete kit for $149.95, and if you want us to rebuild your crank as well that would run $59.00
Thanks,
Don
http://www.elsinores.com
Author:  Scrappy [ Tue Oct 25, 2005 7:36 pm ]
Thanks all for the info. FYI, Crank Works said they sold the last rod kit for the 73-74s.
