It is currently Fri Jul 04, 2025 9:39 pm
PostPosted: Thu Sep 08, 2005 10:52 am
I have a 74 MT 250 elsinore motor and wanted to know if I could use the head and cylinder on my 73-74 cr 250.? Are they the same or different? what other parts are interchangable? My serial # is Mt 250E 1001029
PostPosted: Thu Sep 08, 2005 11:14 am
They are different but you can interchange them. A major difference is the MT intake manifold uses 2 bolts instead of 4 so you have to use it and an MT carb. Mostly 73-74 CR250s will work with 74-76 MTs.
CR rings/pistons changed in 75 but I think you can get away with using a 75-76 CR piston in a 73-74 CR or 74-76 MT if you right rings as the wrist pin and bores are basically the same.
PostPosted: Thu Sep 08, 2005 11:20 am
Thanks for the info. I looked at the MT intake and it has four bolts just like my cr. Are the ports any different and is the bottom end gears the same? thanks
PostPosted: Thu Sep 08, 2005 7:09 pm
If you have four bolts holding on the intake and a 34mm carb instead of the 28mm MT carb then you have a 73-74 CR250 cylinder on there already.
PostPosted: Thu Sep 08, 2005 7:14 pm
thats sounds like what I have except I don't have the carb. but the intake looks exactly the same size as cr's. How do I tell what bore the cylinder is on? what MM is the standard bore? Thanks
PostPosted: Sat Sep 10, 2005 10:20 am
If you go to the Wiseco Web page they list sizes. 70 mm is standard bore
http://www.wiseco.com/PDFcatalogs/CB05_honda.pdf
74 MT-250
06 Husky TE-450
