1973 honda cr250 elsinore rod help needed
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=794
Author:  hotrodlincoln [ Thu Oct 06, 2005 6:32 pm ]
Post subject:  1973 honda cr250 elsinore rod help needed
Hey guys, replacing the rod in my cr and wanted to find out what is available out there? whats the best? seem to find alot of this Hot Rod but it has a spacer. Is that Ok. Might race it - who sells and is dependable- thanks alot!!!
Author:  FirePig [ Sat Oct 08, 2005 10:22 am ]
There's an ad for crank rebuild kits on the AHRMA Web Mart site. I don't know anything as to quality one way or the other.
http://www.ahrma.org/mart/webmart.htm?
Author:  hotrodlincoln [ Mon Oct 10, 2005 6:31 pm ]
Loren, I just wanted to thank you for the rod link . Thanks for always providing good information regardless of how crazy the questions. HRL
Author:  Rick [ Wed Oct 19, 2005 10:47 pm ]
One of my son's used to work at Crank Works in AZ.
He modified the crank (I think he had to drill out the hole for the larger pin, put the new CR rod kit on and balanced it (needs complete piston, rings, bearing, pin and circlips to balance it). I got a spacer from the www but it is made by Comic (sp?) and was plug and play. The new CR rod kit is stronger than the stocker. After this, a crank re-build is easy as parts are everywhere for newer CR's.
My bike is far from stock and I ride it very hard in the expert class. 9k + RPM's (guessing), no vibrations and no problems at all.
Rick
