It is currently Fri Jul 04, 2025 10:00 pm
 Post subject: Cylinder interchange
PostPosted: Tue Oct 11, 2005 6:53 pm
Is it possible to put a 1977 MR 175 cylinder and piston on a 1977 CR 125?
Thanks,
Dan
 Post subject: 77 mr175 cylinder
PostPosted: Tue Oct 11, 2005 8:23 pm
The porting may not be the same. Compare the two cylinders but I bet they are not the same. I believe the piston is larger too.
PostPosted: Wed Oct 12, 2005 11:16 pm
Won't work. MR175 mounts the cylinder with long studs from the cases all the way thru the cylinder and head. CR125 mounts with standard shorts studs just to the cylinder. Unless you pulled the long studs out of a MR175 set of cases and put them in the CR125 cases it would be undoable and impractical.
