It is currently Sat Jul 05, 2025 3:19 am
PostPosted: Thu Oct 20, 2005 8:29 pm
Can anyone tell me why the bridged intake port has different heights?
Can I grind the lower height to match high port?
I have a fabricated reed valve assy to be fitted to my '75 CR250M and would like to know if any cylinder porting can be done to compliment the reed assy?
This cycle will be use for vintage MotoX racing only.
PostPosted: Fri Oct 21, 2005 10:37 pm
The lower port on the right side is there because the lower ring gap is there. It holds the ring in tight. If you do raise the port, which I inadvertently did, you can run just the top ring as I do or you can repin the ring gap pin on the piston.
My advice is to just leave it alone or raise it just a little bit but not enough to expose the ring gap.
Loren Davis
51y
PostPosted: Sun Oct 23, 2005 2:32 pm
Thanks for that Loren.
I will leave it alone.
John
Users browsing this forum: Google [Bot] and 20 guests
