Clutch Removal Question-MT 250.
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=816
Author:  wrreed [ Sun Oct 30, 2005 11:32 pm ]
Post subject:  Clutch Removal Question-MT 250.
Re: 76 MT 250:
I want to remove my clutch to check my basket/plates etc. as Prev. Owner did not maintain bike well and clutch won't work.
Which direction do I need to go to remove the nut on the clutch? Lefty Loosey/Rightey Tightey?
Also, would someone please share the crankcase oil capacity for this model.
W.R. :?
Author:  redrocket190 [ Mon Oct 31, 2005 8:33 am ]
All the clutches I have worked on were standard threads. The nut is normally secured with a tab washer so you will need gently bend the tab back down flat before you try and loosen the nut. I use a Motion Pro clutch holder to hold the basket while undoing the nut. Good luck!
