It is currently Sat Jul 05, 2025 3:02 am
 Post subject: Mulholland shocks
PostPosted: Sat Dec 03, 2005 3:44 am
I'm trying to find some oil seals for a set of mulholland shocks
without much luck does anyone have any Idea where I can get some
thanks for any help Simon :twisted:
 Post subject: Shocks
PostPosted: Mon Dec 05, 2005 9:38 pm
If you can get the shocks apart and get the seals out just measure them. I rebuilt some muhollands just using a generic seals from a seal supplier. I did not write down the sizes but they are relatively common. As long as you get them in straight they should not leak and will last about as long as the originals.
PostPosted: Tue Dec 06, 2005 1:46 pm
:( I did get the seals out and I phoned a shock repairer and he told me there not a standard size , I can get hold of some seals that fit, but I will need to drill the hole out to fit the shaft I'll have to give it a try
outer diameter 25mm
> inner diameter 12mm
> depth 14mm
Users browsing this forum: Google [Bot] and 21 guests
