CR125 Coil Test https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=9 |
Author: | Dwane [ Mon Apr 07, 2003 4:47 pm ] |
Post subject: | CR125 Coil Test |
Anyone know how to test a coil for a CR125 (74-78) without it being on the bike? Thanks! |
Author: | Barry [ Mon Apr 07, 2003 4:48 pm ] |
Post subject: | Re: CR125 Coil Test |
You can check continuity with an ohmmeter. put the ohmmeters -(neg) lead on the metal mount or Green wire of the coil. Then put the +(pos) lead in the plug wire. Using the ohm setting on the meter it should move up a bit. Then put the +(pos) lead to the white/black wire. It should also move. If there is no movement its bad. The green wire should be (+) and the white/blue (-). Hope that helps a little. |
