will a 75 elsinore 250 seat fit a 73/74 https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=907 |
Author: | hotrodlincoln [ Thu Feb 09, 2006 9:06 pm ] |
Post subject: | will a 75 elsinore 250 seat fit a 73/74 |
Just trying to figure out if the 75 seat will fit the 73/74 cr 250 elsinores? thanks |
Author: | ricortes [ Fri Feb 10, 2006 11:47 am ] |
Post subject: | |
No, different front bracket and position of rear bracket. But it is a close miss if you get the seat cheap enough, need something right now, and don't mind making your own attachment points. |
Author: | Elsinorestuff [ Thu Feb 16, 2006 10:23 pm ] |
Post subject: | |
I made a 1976 seat fit a 1974 buy taking the front tab off the 74 seat base and attaching it to the 76 plastic seat base. Then I made two short adapters from 1 inch aluminum strips bolted to the 76 seat brackets and another hole drilled to line up with the 74 frame. |
