Fox Air Shox pump
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=917
Author:  rossvickicampbell [ Fri Feb 17, 2006 12:24 am ]
Post subject:  Fox Air Shox pump
Good afternoon ladies and gents,
for those of you out there lucky enough to have a set of Fox air shox could you please point me in the right direction for finding a suitable pump to adjust the pressures. According to the manual a normal high pressure won't do so what better than to try our forum and see if someone out there can help.
Thanks in advance guys.
regards
Author:  redrocket190 [ Fri Feb 17, 2006 5:38 pm ]
I suggest going to your local mountain bike store and picking up a shock pump. I have one from Risse Technology. It comes with a doodad that allows the pump to be removed from the shock without losing any pressure so the setup is 100% accurate.
Author:  rossvickicampbell [ Fri Feb 17, 2006 7:49 pm ]
thank you very much - shall check that out ASAP
